290x and QX270LED
10-29-2013, 01:54 AM
290x and QX270LED
Hi everybody!
I just bought a Radeon r9 290x and a Qnix QX2710 monitor. Everything is awesome except one thing. When I run any of the tests at Testufo.com it shows that I always have 63hz. I followed the instructions to overlocking the monitor and I can select any of the settings that I made in CCC. I am not sure what the problem is. I feel like I can tell a difference when I change the refresh rate from 60 to 110 hz. Maybe my eyes are playing tricks on me? Just testufo always says I am running at 63hz. Also I am using the lastest beta drivers and google chrome to test it. The patcher shows that everything works too. any ideas? Thanks! |
10-29-2013, 02:19 AM
RE: 290x and QX270LED
That would indicate a frame rate problem with the test and not necessarily a problem with the overclock. Browsers can be finicky about this. If you're using multiple monitors, try disconnecting the other ones.
