Help for my 1080p monitor.
02-23-2015, 11:34 PM
Hi! I have a Asus G750JX laptop. It's lcd monitor was crashed. So i connect it with a tv and then i changed it's lcd panel with new one. My scren resolution is 1920x1080 pixels but native resolution seem 1600x900 pixels. So I used Custom Resolution Utily(CRU) and fix it. But the resolution is stil 1600x900 pixels in first starting and bios screen. Please help me for fix it. It look like that :[Image: http://i62.tinypic.com/vzwsis.jpg]
02-25-2015, 03:52 AM
RE: Help for my 1080p monitor.
If the panel has its own EDID, then it should have come with the correct resolution already set. The only way to fix the startup resolution is to flash the EDID. I don't have instructions for doing that, but CRU can export .bin files that you can use if you can find a utility that works with your hardware.
02-25-2015, 10:22 PM
(Last edited: 02-25-2015, 10:23 PM by ErenMR)
Thanks for answer. I'm working on the .bin file. But I think, it just utility on Windows. So, I have to find a way for flashing hardware settings.
