Help with 14.9 monitor
02-23-2021, 01:59 PM
I have a rx 480 and a 14.9 long monitor.
Window only show 1280x960, 1280x 768 and 1024x768 as resolution, it suppose to be 1280x390.
I tried set 1280x390 at 68hz. I saw someone have luck with that, after run the restart64 or restart. The custom resolution didnt show up. I am not sure what went wrong.
What do I need to do?
02-23-2021, 06:45 PM
RE: Help with 14.9 monitor
Windows will not list resolutions less than 480 lines, but it's available for programs to use. You can use this program to set the resolution: https://funk.eu/hrc/
02-24-2021, 02:53 AM
(02-23-2021 06:45 PM)ToastyX Wrote:  Windows will not list resolutions less than 480 lines, but it's available for programs to use. You can use this program to set the resolution: https://funk.eu/hrc/
thanks i will give it a try tomorrow.
02-25-2021, 07:52 PM
i dont see how i can use hrc to change the resolution to 1280x390? i dont see the 120x390 option at all. did i miss something?
02-26-2021, 07:55 PM
Is it not in the drop-down list? How are you adding 1280x390 in CRU?
