No audio through HDMI @75hz even with audio block
05-29-2020, 06:53 AM
Hi i have an rx470 8gb running the latest AMD drivers and a dell monitor (s2316h), so far i can overclock it to 75Hz with reduced timings 164.7MHz total due to the hdmi limits i think. But the problem is no audio comes out when i enable 75hz on windows, the audio comes back as soon as i switch to 60 though. As far as im concerned i just copied the original data blocks
05-29-2020, 08:32 AM
RE: No audio through HDMI @75hz even with audio block
Audio is transmitted during the blanking periods, so you can't have audio with reduced horizontal timing parameters.
