Overclocking problem
08-03-2019, 12:34 PM
Hi, this isn't a problem with CRU, but with the overclocking process itself.
I've got an ASUS VW222U (Native resolution is 1680x1050@60hz), and I tried overclocking it with Intel HD Graphics panel. I was able to get up to 72hz, but the problem is - the resolution gets sort of messed up. The whole screen seems stretched, I can barely see the task bar (since the screen was stretched) and everything seems really blurry. I've tried auto-adjusting the monitor, did not help, I've tried shifting everything manually, but it didn't seem to help either. Now, with CRU, the options that I add do not even appear after restarting my computer or restarting my graphics driver. |
08-04-2019, 02:43 AM
RE: Overclocking problem
Are you using DVI? What Intel CPU do you have? What version of Windows?
