icons go pixelated after using cru to overclock my monitor
06-09-2023, 07:12 PM
(Last edited: 06-09-2023, 07:37 PM by kray)
small icons go pixelated after using CRU to overclock my monitor
monitor: prism f220 display port my monitor is 1920 1080 144hz and I overclocked to 1920 1080 165hz it works well but it's pixelated and it's only in CRU I overclocked to 165hz in the Nvidia control panel works fine but there are a lot of video games that can't detect it so I'm trying to use cru also, I notice a thing. when I set my digital vibrance to 0 it fixed the pixelated problem but it's just black and white... and I guess it's the color format problem but I have 0 idea how to change them... the pixelated pictures: https://imgur.com/a/7vySvgi| pls help :3 when I use cru, it only gives me YCbCr422 instead of RGB and I don't know how to change it (color format) even in the Nvidia control panel, I can only use YCbCr422 but when I use my 144hz resolution, I can use RGB and more I found the answer. I have to unpick the color formats in the display properties ![]() I hope this helps some of you ^-^ |
