4K60hz problem AMD
11-17-2018, 03:54 PM
4K60hz problem AMD
Hi everyone , i try force 4k60hz option. CRU and AMD PIXEL CLOCK INSTALLED. (In CRU ,Delete all blocks-creat new Tv Res 4:2:0 4k 60hz) i have 30-59-60 hz option in windows , i accept and black screen. NO SINGNAL :/
ANY tipps? Please help Smile
Fx 8350
Hd7950 oc hdmi 1.4a
thomson 55uc6306 (hdr and 4k 60hz supported)
11-18-2018, 12:37 AM
RE: 4K60hz problem AMD
Don't use the pixel clock patcher, and make sure you have the HDMI support data block.
11-18-2018, 01:16 PM (Last edited: 11-18-2018, 01:19 PM by Slackplay)
(11-18-2018 12:37 AM)ToastyX Wrote:  Don't use the pixel clock patcher, and make sure you have the HDMI support data block.
Hi and what settings use Hdmi support ?
(I try full base datablocks + added 4:2:0 res , and dont have 60hz option in windows )
11-20-2018, 03:00 AM
Export a file and post it here so I can see if there's anything wrong.
11-20-2018, 11:58 AM
(11-20-2018 03:00 AM)ToastyX Wrote:  Export a file and post it here so I can see if there's anything wrong.
Alright
.bin  4k60hzproblem.bin (Size: 256 bytes / Downloads: 501)
11-27-2018, 05:18 PM
Try removing 3840x2160 @ 60 Hz from the detailed resolutions.
