Can anyone help me understand the EDID from my display (TV monitor)?
11-28-2021, 11:17 AM
I purchased a thunderbolt 3 usb-C interface to connect a 2019 MBP AMD / Intel to my monitor. Then I went through a few posts regarding setting the refresh rate and resolution. I was unable to set the refresh rate to 60Hz.
However all the HDMI ports on the TV monitor are marked 4k@60Hz. Then after searching around I found a tool people claimed allowed you to set the refresh rate. Unfortunately my work computer does not allow me to have administrator access required by the tool to set a custom EDID. (however I do seem to have some root and some sorts of admin like access)
Regardless I was able to dump the existing EDID. Reading through most of the information dump below, it looks like most of the settings only show 4k@30Hz max. But there is one extra section I'm curious about, that is Data Block #5 which seems to mention two 4k@60Hz resolutions .
This elicts the following inquiry:
With DataBlock #5 should the laptop already support the refresh rate?
Is Mac OS perhaps providing an overlay for my monitor that's ignoring this Data Block 5 video modes?
https://makerforce.io/modifying-macos-di...solutions/
Should I feel safe trying to add or remove an overlay in an attempt to get the 4K@60Hz working from the display ?
Should I try to remove an existing overlay first expecting that it's "blocking" the information provided in data block #5?
Data Block #5
Extended Data Block: YCbCr 4:2:0 video data block
VIC # 0: ( 97) 3840 x 2160 @ 60Hz - 16:9
VIC # 1: (102) 4096 x 2160 @ 60Hz - 256:135
Code:
------------------- RAW DATA ------------------------
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
0 | 00 FF FF FF FF FF FF 00 4D 10 00 00 F8 0F 00 00
1 | 29 1C 01 03 80 90 51 78 0A 8A 5D A4 55 52 9F 25
2 | 0E 47 4A AD CF 00 71 4F 81 40 81 80 81 00 95 00
3 | B3 00 D1 C0 81 C0 04 74 00 30 F2 70 5A 80 B0 58
4 | 8A 00 20 C2 31 00 00 1E 02 3A 80 18 71 38 2D 40
5 | 58 2C 45 00 20 C2 31 00 00 1E 00 00 00 FC 00 4C
6 | 43 36 35 51 37 33 2B 0A 20 20 20 20 00 00 00 FD
7 | 00 17 4C 0F 51 22 00 0A 20 20 20 20 20 20 01 AA
0 | 02 03 32 71 4E 5F 5D 64 62 10 22 20 05 04 3E 3C
1 | 02 01 06 29 09 07 07 15 07 50 57 07 00 6D 03 0C
2 | 00 20 00 B8 3C 20 00 60 01 03 04 E2 00 CF E3 0E
3 | 61 66 04 74 00 30 F2 70 5A 80 B0 58 8A 00 20 C2
4 | 31 00 00 1E 02 3A 80 18 71 38 2D 40 58 2C 45 00
5 | 20 C2 31 00 00 1E 01 1D 00 72 51 D0 1E 20 6E 28
6 | 55 00 20 C2 31 00 00 1E 66 21 50 B0 51 00 1B 30
7 | 40 70 36 00 00 00 00 00 00 18 00 00 00 00 00 68
< 00FFFFFF FFFFFF00 4D100000 F80F0000 291C0103 80905178 0A8A5DA4 55529F25 0E474AAD CF00714F 81408180 81009500 B300D1C0 81C00474 0030F270 5A80B058 8A0020C2 3100001E 023A8018 71382D40 582C4500 20C23100 001E0000 00FC004C 43363551 37332B0A 20202020 000000FD 00174C0F 5122000A 20202020 202001AA 02033271 4E5F5D64 62102220 05043E3C 02010629 09070715 07505707 006D030C 002000B8 3C200060 010304E2 00CFE30E 61660474 0030F270 5A80B058 8A0020C2 3100001E 023A8018 71382D40 582C4500 20C23100 001E011D 007251D0 1E206E28 550020C2 3100001E 662150B0 51001B30 40703600 00000000 00180000 00000068 >
{ 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x4D, 0x10, 0x00, 0x00, 0xF8, 0x0F, 0x00, 0x00, 0x29, 0x1C, 0x01, 0x03, 0x80, 0x90, 0x51, 0x78, 0x0A, 0x8A, 0x5D, 0xA4, 0x55, 0x52, 0x9F, 0x25, 0x0E, 0x47, 0x4A, 0xAD, 0xCF, 0x00, 0x71, 0x4F, 0x81, 0x40, 0x81, 0x80, 0x81, 0x00, 0x95, 0x00, 0xB3, 0x00, 0xD1, 0xC0, 0x81, 0xC0, 0x04, 0x74, 0x00, 0x30, 0xF2, 0x70, 0x5A, 0x80, 0xB0, 0x58, 0x8A, 0x00, 0x20, 0xC2, 0x31, 0x00, 0x00, 0x1E, 0x02, 0x3A, 0x80, 0x18, 0x71, 0x38, 0x2D, 0x40, 0x58, 0x2C, 0x45, 0x00, 0x20, 0xC2, 0x31, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0xFC, 0x00, 0x4C, 0x43, 0x36, 0x35, 0x51, 0x37, 0x33, 0x2B, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x00, 0x00, 0x00, 0xFD, 0x00, 0x17, 0x4C, 0x0F, 0x51, 0x22, 0x00, 0x0A, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x01, 0xAA, 0x02, 0x03, 0x32, 0x71, 0x4E, 0x5F, 0x5D, 0x64, 0x62, 0x10, 0x22, 0x20, 0x05, 0x04, 0x3E, 0x3C, 0x02, 0x01, 0x06, 0x29, 0x09, 0x07, 0x07, 0x15, 0x07, 0x50, 0x57, 0x07, 0x00, 0x6D, 0x03, 0x0C, 0x00, 0x20, 0x00, 0xB8, 0x3C, 0x20, 0x00, 0x60, 0x01, 0x03, 0x04, 0xE2, 0x00, 0xCF, 0xE3, 0x0E, 0x61, 0x66, 0x04, 0x74, 0x00, 0x30, 0xF2, 0x70, 0x5A, 0x80, 0xB0, 0x58, 0x8A, 0x00, 0x20, 0xC2, 0x31, 0x00, 0x00, 0x1E, 0x02, 0x3A, 0x80, 0x18, 0x71, 0x38, 0x2D, 0x40, 0x58, 0x2C, 0x45, 0x00, 0x20, 0xC2, 0x31, 0x00, 0x00, 0x1E, 0x01, 0x1D, 0x00, 0x72, 0x51, 0xD0, 0x1E, 0x20, 0x6E, 0x28, 0x55, 0x00, 0x20, 0xC2, 0x31, 0x00, 0x00, 0x1E, 0x66, 0x21, 0x50, 0xB0, 0x51, 0x00, 0x1B, 0x30, 0x40, 0x70, 0x36, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x68 }
Valid EDID block #0: checksum ok
Valid EDID block #1: checksum ok
------------------- MAIN EDID BLOCK -----------------
EDID Version........1.3
Manufacturer........SHP (4D10)
Product ID..........0 (0000)
Serial Number.......00000FF8
Manufactured........Week 41 of year 2018
Max H Size..........144 cm
Max V Size..........81 cm
Gamma...............2.20
Display Supported Features:
Display type:
RGB color display
Display is non continuous frequency
Default color space is not sRGB standard
First detailed Timing is preferred Timing
Input signal & sync:
Digital Input
Color info:
Red x = 0.643  Green x = 0.322  Blue x = 0.146  White x = 0.280
Red y = 0.332  Green y = 0.623  Blue y = 0.056  White y = 0.290
Established Timings supported:
    \# 0:     720 x  400 @ 70Hz
    \# 1:     640 x  480 @ 60Hz
    \# 2:     640 x  480 @ 72Hz
    \# 3:     640 x  480 @ 75Hz
    \# 4:     800 x  600 @ 60Hz
    \# 5:     800 x  600 @ 72Hz
    \# 6:     800 x  600 @ 75Hz
    \# 7:    1024 x  768 @ 60Hz
    \# 8:    1024 x  768 @ 70Hz
    \# 9:    1024 x  768 @ 75Hz
    \#10:    1280 x 1024 @ 75Hz
Standard Timing supported:
    \# 0:    1152 x  864 @ 75Hz     (714F)
    \# 1:    1280 x  960 @ 60Hz     (8140)
    \# 2:    1280 x 1024 @ 60Hz     (8180)
    \# 3:    1280 x  800 @ 60Hz     (8100)
    \# 4:    1440 x  900 @ 60Hz     (9500)
    \# 5:    1680 x 1050 @ 60Hz     (B300)
    \# 6:    1920 x 1080 @ 60Hz     (D1C0)
    \# 7:    1280 x  720 @ 60Hz     (81C0)
Monitor Description blocks:
Descriptor #0 - Timing definition:
Mode = 3840 x 2160 @ 30.000Hz
    Pixel Clock............. 297.00 MHz        Not Interlaced
Horizontal Vertical
    Active.................. 3840 pixels        2160 lines
    Front Porch.............  176 pixels           8 lines
    Sync Width..............   88 pixels          10 lines
    Back Porch..............  296 pixels          72 lines
    Blanking................  560 pixels          90 lines
    Total................... 4400 pixels        2250 lines
    Scan Rate...............  67.500 kHz         30.000 Hz
    Image Size..............  800 mm             450 mm
    Border..................    0 pixels           0 lines
        Sync: Digital separate with
* Positive vertical polarity
* Positive horizontal polarity
Descriptor #1 - Timing definition:
Mode = 1920 x 1080 @ 60.000Hz
    Pixel Clock............. 148.50 MHz        Not Interlaced
Horizontal Vertical
    Active.................. 1920 pixels        1080 lines
    Front Porch.............   88 pixels           4 lines
    Sync Width..............   44 pixels           5 lines
    Back Porch..............  148 pixels          36 lines
    Blanking................  280 pixels          45 lines
    Total................... 2200 pixels        1125 lines
    Scan Rate...............  67.500 kHz         60.000 Hz
Descriptor #2 - Monitor name:
    LC65Q73+
Descriptor #3 - Monitor range:
    Horizontal frequency range.......15-81 kHz
    Vertical frequency range.........23-76 Hz
    Maximum bandwidth range..........340 MHz
    GTF supported
------------ EXTENSION EDID BLOCK 1 ---------------
CTA-EXT: CTA 861 Series Extension:
Revision:...........................3
First DTD block at offset...........46
Display Supports:
    Basic audio
    YCbCr 4:4:4
    YCbCr 4:2:2
Data Block #1
Video Type: standard CTA Timings
    VIC # 0: ( 95) 3840 x 2160 @ 30Hz - 16:9
    VIC # 1: ( 93) 3840 x 2160 @ 24Hz - 16:9
    VIC # 2: (100) 4096 x 2160 @ 30Hz - 256:135
    VIC # 3: ( 98) 4096 x 2160 @ 24Hz - 256:135
    VIC # 4: ( 16) 1920 x 1080 @ 60Hz - 16:9
    VIC # 5: ( 34) 1920 x 1080 @ 30Hz - 16:9
    VIC # 6: ( 32) 1920 x 1080 @ 24Hz - 16:9
    VIC # 7: (  5) 1920 x 1080i @ 60Hz - 16:9
    VIC # 8: (  4) 1280 x 720 @ 60Hz - 16:9
    VIC # 9: ( 62) 1280 x 720 @ 30Hz - 16:9
    VIC #10: ( 60) 1280 x 720 @ 24Hz - 16:9
    VIC #11: (  2) 720 x 480 @ 60Hz - 4:3
    VIC #12: (  1) 640 x 480 @ 60Hz - 4:3
    VIC #13: (  6) 1440 x 480i @ 60Hz - 4:3
Data Block #2
Audio Data Block
    Supported format:                Linear PCM, on 2 channels
    Supported sample rates (kHz):    32kHz, 44.1kHz, 48kHz
    Supported sample sizes (bits):    16 bit, 20 bit, 24 bit
    Supported format:                AC-3, on 6 channels
    Maximum bitrate:        640 kb/s
    Supported format:                Dolby Digital+, on 8 channels
Data Block #3
Vendor specific Data Block - Vendor Identifier: 00:0C:03 (HDMI)
Found HDMI IEEE Registration Identifier
    CEC physical address........... [2.0.0.0](https://2.0.0.0)
    Supports AI (ACP, ISRC)........ Yes
    Supports 48bpp color depth..... No
    Supports 36bpp color depth..... Yes
    Supports 30bpp color depth..... Yes
    Supports YCbCr 4:4:4........... Yes
    Supports dual-link DVI......... No
    Maximum TMDS clock............. 300 MHz
    HDMI video capabilities........ Yes
    Supports 3D.................... No
    HDMI 1.4a specifics............ present
        HDMI VIC # 1:................. 3840 x 2160 @ 30Hz
        HDMI VIC # 3:................. 3840 x 2160 @ 24Hz
        HDMI VIC # 4:................. 4096 x 2160 @ 24Hz
Data Block #4
Extended Data Block:     Video Capability Data Block
    CE scan behaviour: Support both over- and underscan
    IT scan behaviour: Support both over- and underscan
    PT scan behaviour: No Data
    RGB quantization: Selectable (via AVI Q)
    YCbCr quantization: Selectable (via AVI Q)
Data Block #5
Detailed Timing Blocks - 1 is native
Detailed Timing Block #1 - Timing definition:
Horizontal Vertical
Detailed Timing Block #2 - Timing definition:
Horizontal Vertical
Detailed Timing Block #3 - Timing definition:
Mode = 1280 x  720 @ 60.000Hz
    Pixel Clock............. 74.25 MHz        Not Interlaced
Horizontal Vertical
    Active.................. 1280 pixels         720 lines
    Front Porch.............  110 pixels           5 lines
    Sync Width..............   40 pixels           5 lines
    Back Porch..............  220 pixels          20 lines
    Blanking................  370 pixels          30 lines
    Total................... 1650 pixels         750 lines
    Scan Rate...............  45.000 kHz         60.000 Hz
Detailed Timing Block #4 - Timing definition:
Mode = 1360 x  768 @ 60.015Hz
    Pixel Clock............. 85.50 MHz        Not Interlaced
Horizontal Vertical
    Active.................. 1360 pixels         768 lines
    Front Porch.............   64 pixels           3 lines
    Sync Width..............  112 pixels           6 lines
    Back Porch..............  256 pixels          18 lines
    Blanking................  432 pixels          27 lines
    Total................... 1792 pixels         795 lines
    Scan Rate...............  47.712 kHz         60.015 Hz
    Image Size..............    0 mm               0 mm
* Negative vertical polarity
* Negative horizontal polarity
11-28-2021, 04:26 PM
RE: Can anyone help me understand the EDID from my display (TV monitor)?
Adding a resolution that should already exist won't work because there has to be a reason why the resolution isn't available. 3840x2160 @ 60 Hz requires either HDMI 2.0 or YCbCr 4:2:0, but the TV is not reporting HDMI 2.0, and I don't know if macOS supports YCbCr 4:2:0 for your laptop. There might be some setting that needs to be enabled on the TV for HDMI 2.0, but I can't find a manual or any useful information about the TV online. The USB-C adapter also needs to support HDMI 2.0, but that wouldn't affect the EDID.
11-28-2021, 06:55 PM (Last edited: 11-28-2021, 08:20 PM by discord)
(11-28-2021 04:26 PM)ToastyX Wrote:  Adding a resolution that should already exist won't work because there has to be a reason why the resolution isn't available. 3840x2160 @ 60 Hz requires either HDMI 2.0 or YCbCr 4:2:0, but the TV is not reporting HDMI 2.0, and I don't know if macOS supports YCbCr 4:2:0 for your laptop. There might be some setting that needs to be enabled on the TV for HDMI 2.0, but I can't find a manual or any useful information about the TV online. The USB-C adapter also needs to support HDMI 2.0, but that wouldn't affect the EDID.
It's funny because every HDMI port on the back of the TV is marked 3840x2160 @ 60 Hz.
I will eventually be dual booting a linux variant via t2linux, if there's any flexibility.
The usb-c <-> hdmi adapter is marked as thunderbolt 3 compatible and supporting 3840x2160 @ 60 on amazon. Then I will have to try it on another monitor.
Regarding HDMI 2.0. I thought that supported extra bandwidth beyond 10Gb / s so 4:2:2 support was possible. I was under the impression that 4:2:0 used under 10Gb / s but I'm just exposing my ignorance.
Some more details about graphics cards and displays from System Information.
AMD Radeon Pro 5500M:
Chipset Model: AMD Radeon Pro 5500M
Type: GPU
Bus: PCIe
PCIe Lane Width: x8
VRAM (Total): 4 GB
Vendor: AMD (0x1002)
Device ID: 0x7340
Revision ID: 0x0040
ROM Revision: 113-D3220E-190
VBIOS Version: 113-D32206U1-020
Option ROM Version: 113-D32206U1-020
EFI Driver Version: 01.A1.190
Automatic Graphics Switching: Supported
gMux Version: 5.0.0
Metal Family: Supported, Metal GPUFamily macOS 2
Displays:
Color LCD:
Display Type: Built-In Retina LCD
Resolution: 3072 x 1920 Retina
Framebuffer Depth: 30-Bit Color (ARGB2101010)
Main Display: Yes
Mirror: Off
Online: Yes
Automatically Adjust Brightness: Yes
Connection Type: Internal
LC65Q73+:
Resolution: 3840 x 2160 (2160p/4K UHD 1 - Ultra High Definition)
UI Looks like: 3840 x 2160 @ 30.00Hz
Mirror: Off
Online: Yes
Rotation: Supported
Automatically Adjust Brightness: No
Connection Type: DVI or HDMI
Adapter Firmware Version: 7.55
Television: Yes
Intel UHD Graphics 630:
Chipset Model: Intel UHD Graphics 630
Type: GPU
Bus: Built-In
VRAM (Dynamic, Max): 1536 MB
Vendor: Intel
Device ID: 0x3e9b
Revision ID: 0x0002
gMux Version: 5.0.0
11-28-2021, 08:25 PM (Last edited: 11-28-2021, 10:41 PM by discord)
On this spec sheet it appears to be HDMI 2.0
11-28-2021, 10:47 PM (Last edited: 11-28-2021, 10:48 PM by discord)
Found the product page to the model number corresponding to the back of the TV https://www.sharptvusa.com/support/model...-65q7330u.
In the spec sheet https://assets.sharptvusa.com/assets/Pro...oc-v01.pdf
It clearly shows HDMI 2.0 inputs.
Right now I presume what is happening is that MAC OS is overlaying the EDID information. We also see that the EDID information does not contain the exact model number. I might try my own overlay because the product documentation states the device ports are HDMI 2.0
11-29-2021, 01:26 AM
(11-28-2021 06:55 PM)discord Wrote:  Regarding HDMI 2.0. I thought that supported extra bandwidth beyond 10Gb / s so 4:2:2 support was possible. I was under the impression that 4:2:0 used under 10Gb / s but I'm just exposing my ignorance.
Technically YCbCr 4:2:0 was not officially supported until HDMI 2.0, but 3840x2160 @ 60 Hz can fit within HDMI 1.4 bandwidth with YCbCr 4:2:0, which is what the TV defines, but macOS does not seem to support that with your laptop because it's being ignored.
(11-28-2021 10:47 PM)discord Wrote:  Right now I presume what is happening is that MAC OS is overlaying the EDID information. We also see that the EDID information does not contain the exact model number. I might try my own overlay because the product documentation states the device ports are HDMI 2.0
MacOS would not change the EDID in that way. This is a problem with the TV. The TV is not reporting HDMI 2.0, and it's only reporting 3840x2160 @ 60 Hz with YCbCr 4:2:0.
That leaves only four possibilities:
1. Some setting needs to be changed in the TV to enable HDMI 2.0.
2. Only some of the ports actually support HDMI 2.0 despite the labeling.
3. The TV supports HDMI 2.0, but is not reporting it correctly.
4. The TV doesn't actually support HDMI 2.0.
11-29-2021, 06:58 AM
Since the manual states all ports are HDMI 2.0 and we see YCbCr 4:2:0 described, we might assume 3. The TV supports HDMI 2.0, but is not reporting it correctly.
Then can I use an overlay to try to add the mode?
11-29-2021, 09:39 AM
I think I eliminated
I went through all the TV menus I could find and didn't find anything specific. What settings I did try, game mode, direct input vs notable input did not allow macOS to choose 60Hz
I tried 2 of the three inputs. Again no 60Hz.
One other thing that's funny is the "preferred" resolution seems to be 1920x1080 @ 30Hz if I recall correctly. Unless they were false advertising the set, I would assume it is supposed to have HDMI 2.0 based on the documentation https://www.sharptvusa.com/support/model...c-65q7330u
Finally some people claim macOS cannot properly read EDID https://github.com/Akemi/macOS-edid-modification
