Decreasing monitor delay
10-03-2015, 10:42 PM
I have a 1080p monitor(HDTV) that in vga mode shows only 1600x900, so i used CRU and i created a 1920x1080 resolution, and it works perfectly.
I noticed that using "LCD reduced" the monitor's delay decreases.
Can i further decrease the delay editing the "Front porch", "Sync width", and "Back porch"'s values? If yes, decreasing or increasing values?
10-04-2015, 12:32 AM
RE: Decreasing monitor delay
I've never seen timing parameters affect monitor lag. That must be a quirk with your particular TV. Maybe using non-CEA or "PC" timing parameters disables some image processing. For 1920x1080 @ 60 Hz, "LCD standard" uses the CEA standard, while "LCD reduced" uses the CVT-RB standard, which the TV might be identifying as a "PC" resolution.
10-04-2015, 07:29 AM
Ok i understand, Thank you (:
