Help Overclocking ASUS VN247
01-31-2015, 11:20 PM
My friend showed me this forum and i decided to try out the 'Custom Resolution Utility'. The maximum i was able to squeeze out was 74Hz which is ok, but I was wondering if it's possible for me to at least reach 80Hz. I have ASUS VM247 monitor, GTX 660TI GPU and I'm using HDMI 1.4b cable.
Thank you.
02-03-2015, 03:52 PM
RE: Help Overclocking ASUS VN247
Most monitors will not accept more than 77 Hz. The only thing you can do is try playing with the timing parameters.
1. Try adding a detailed resolution and just changing the refresh rate without changing the timing parameters.
2. Try using the "LCD reduced" option. That might not work in the 75-78 Hz range, depending on the monitor.
3. Try the "LCD standard" option.
