Parts required for overclocking LG IPS panels?
05-22-2015, 06:27 PM
RE: Parts required for overclocking LG IPS panels?
I have a Dell U2711 and I broke the LCD panel after a shock on the screen with a cup
![]() I called to Dell and they asked me 900 euros for a refurbished panel! At the beginning, I planed to buy a new LG panel LM270WQ2 but the part is difficult to find, and the prices are high... After some researches I found: - the LM270WQ1 which is less expensive and easier to find because more Apple monitors was sold compared to the Dell monitor. - the LM270WQ3 which is used in other monitors Here is my key interrogation: can I plug in my Dell U2711 the Q1 or Q3 panel ? If so, what kind of manual adaptations have I to do ? Please note that I am not concerned if I lost some functions of my screen or if the final performances are a little but lower. Regards, Benjamin |
05-23-2015, 04:41 PM
Supposedly the timing controller is interchangeable between the LM270WQ2 and the LM270WQ1, but the LM270WQ2 has CCFL backlighting while the LM270WQ1 has LED backlighting, so I don't know if the backlight control is interchangeable. Even if it worked, the LM270WQ2 is a wide gamut panel while the LM270WQ1 is a standard gamut panel, so the colors will look different. I think you're better off just getting a new monitor like one of the Korean 2560x1440 monitors on eBay.
07-01-2015, 09:00 PM
Well after many months of search, failed purchases, etc. I have finally got the required parts and managed to OC my Shimian to 120Hz!
![]() I uploaded the frame skipping test on You Tube, @ToastyX what do you think? Are those 120Hz valid? It may be capable of more than that but my 290x i struggling to achieve constant 120 fps already. https://www.youtube.com/watch?v=67x0eLJ-5Og |
07-02-2015, 04:10 AM
Post: #14
(07-01-2015 09:00 PM)Miskonius Wrote: Well after many months of search, failed purchases, etc. I have finally got the required parts and managed to OC my Shimian to 120Hz!Definitely looks like real 120 Hz. |
07-07-2015, 06:42 AM
Post: #15
Hi Miskonius,
Could you please tell us where you got the correct parts from (and what they were). Any help would be greatly appreciated |
07-08-2015, 07:23 AM
(Last edited: 07-08-2015, 07:24 AM by Miskonius)
Post: #16
(07-02-2015 04:10 AM)ToastyX Wrote:(07-01-2015 09:00 PM)Miskonius Wrote: Well after many months of search, failed purchases, etc. I have finally got the required parts and managed to OC my Shimian to 120Hz!Definitely looks like real 120 Hz. Thanks ToastyX! I even managed to get it up to 130Hz, frame skipping test looks OK it works fine in games but I am getting a lot of flashes when browsing so I left it at 120Hz. I tried 140 Hz but for some reason Windows is refusing to accept it. (07-07-2015 06:42 AM)therockwwe Wrote: Hi Miskonius, You need: Logic board LM270WQ1-SLA1 Driver board LM270WQ1 /LDK-LE256/HY-2560M You can get them at overlordcomputer.com for $200 OC PCB set or you can try at on Chinese taobao.com and use yoybuy.com to purchase it for you. I bought driver board from overlord (~$90 with shipping) and logic board from China ($50 with shipping) which ended up $140. You can only buy the driver board at overlord since the guy who sells them in China sanelin88 does not respond to messages. |
07-09-2015, 03:16 AM
Post: #17
Damn...looks like overlordcomputer.com has gone out of business
07-09-2015, 11:15 AM
Post: #18
Damn I guess you are right.
Talk about a last minute purchase on my part. ![]() Ask sanelin88 over here http://en.agreetao.com/item/37901630265 he might answer. It occurred to me that he might be ignoring yoybuy because he knows that its for foreigners for which he charges extra. |
07-23-2015, 10:39 PM
Post: #19
Thanks once again Miskonius. (Great info and help!)
Do you know where to get the original Driver board from (the non 100hrz DVI board)? |
07-24-2015, 06:41 AM
Post: #20
taobao.com and use yoyobuy.com as a mediator
