[Solved] Force resolution on VGA monitor (that is compatible)
02-15-2024, 05:40 PM
(Last edited: 02-19-2024, 04:39 AM by Fede)
I have an AMD RX6600XT 8GB GPU, which is connected to an old Samsung SyncMaster 2343NWX monitor.
Monitor input is VGA, and card output is HDMI. I'm using a HDMI splitter (connected to an optional 5V power source, which I use USB from the motherboard) and at its output there is a HDMI to VGA adaptor. Monitor native resolution is 2048x1152, and it works pretty well with this setup. Except for the folowing: The problem I am facing is that when I turn off the computer and turn it on again, it changes the resolution to 1920x1080 without the option to set 2048x1152. If I unplug the HDMI cable and plug ir back again, it automatically connects my monitor and set the resolution to 2048x1152. What I would like to do is to force Windows to set the 2048x1152 after each boot, or how other way can I troubleshoot this situation. Once I get the desired resolution, monitor works perfectly for hours. Any idea? |
02-16-2024, 03:13 AM
RE: Force resolution on VGA monitor (that is compatible)
That seems like an AMD driver bug. Try disabling fast startup: https://www.asus.com/support/faq/1045548/
02-19-2024, 04:38 AM
(02-16-2024 03:13 AM)ToastyX Wrote: That seems like an AMD driver bug. Try disabling fast startup: https://www.asus.com/support/faq/1045548/ That worked, thank you! |
