hi everyone i need help
07-31-2016, 02:54 PM
(Last edited: 07-31-2016, 02:58 PM by 1967kID)
i got a hp pavilion 27xi monitor the max i can get is 70 mhz with cru_126 with amd patcher 136 maybe its because of my video card its a old one visiontek hd 7850 2 gig thank you 1967kID
09-21-2016, 08:45 AM
RE: hi everyone i need help
What are your current timings?
These are the timings I currently use. Basically, you want to find the lowest blanking timing your monitor can handle. Note that as you change the front/back porch and sync width, the blanking will change as well. That is, the blanking is the sum of front/back porch and sync width. (07-27-2016 01:46 AM)ToastyX Wrote:(07-25-2016 07:00 AM)BLUuuE Wrote: I found that my minimum horizontal blanking is 56. Does it matter what front, sync and back timings are? Like is there a difference between 8/8/40 and 16/16/24 ?That depends on the monitor. Usually it doesn't matter. Just use whatever works. |
