need help overclockin
11-03-2013, 12:00 AM (Last edited: 11-03-2013, 12:03 AM by sipe)
Hello i am new here and i want to overclock my monitor becouze i play cs go and i need the most frames i can get.My monitor is Samsung SyncMaster s22b350h and when i overclock it trough nvidia custom resolution it can do 82 on 1024x768 it passes the test and all but when i try it it says not optimum resolution and after 1 min it goes black and if i turn of my monitor and turn it back on same process happenes again after 1 min black.If anyone can tell me what the problem is i would be very gratefull thank you
i forgot to mention the 1024x768 is in aspect ratio 4:3 not streched and this is really weird cuz it's so low pixel clock and i tried 1920x1080 at 75 and it works the monitor doesnt say not optimum resolution
11-03-2013, 12:16 AM
RE: need help overclockin
The problem is the monitor is programmed to not accept 82 Hz. There's no way around that. Most monitors top out around 70-77 Hz.
