vga monitor refresh rate overclock
07-29-2013, 09:52 PM
Hi guys
I've got e-machines e17t6w monitor with 75hz standard refresh rate @ 1440x900 i must overclock refresh rate how high i can bcz i play online fps games , higher hz - better game performance , you know. i've got geforce 9600 gt with 304.48 driver windows 7 64 bit i installed the tempest monitor drivers (Tempest X270OC) patched with nvlddmkm-patcher-1.1.5 (and 1.1.6 too..) and @ nvidia control panel , at ALL resolutions i can set only 78 hz (142.3Mhz) at 78hz monitor works , but when i set to 79 or 80 or 120 or 96.. you know i see a black monitor with "FREQUENCY OUT OF RANGE" title... how to set this monitor to higher refresh rate ? Can i oc this monitor for 85hz maybe? Please for fast respond , waiting for experienced guys replies Thanks , turu. |
07-30-2013, 02:15 PM
RE: vga monitor refresh rate overclock
Try "CVT reduced blank" in the NVIDIA control panel. If that doesn't help, then the monitor doesn't support higher refresh rates.
You can't make the monitor accept a higher refresh rate. Most LCD monitors will not accept 85 Hz. |
07-30-2013, 05:55 PM
(Last edited: 07-30-2013, 05:57 PM by turu)
I tryed cvt reduced blank , only 78hz... can't to maybe 80 max? And when i put 78hz aspect ratio is bugged , i got fullscreen when i need aspect ratio.. why i need to do?
there is no vga patcher or what? 78hz is so low :/ |
07-30-2013, 06:40 PM
The patch is for driver limits, not monitor limits. You can't get around monitor limits with software.
07-30-2013, 07:03 PM
(Last edited: 07-30-2013, 07:03 PM by turu)
so what i can do now? for only 80 hz not 78? This is a solution for my situation or 78hz is max ? And what i must do for this aspect ratio?
"And when i put 78hz aspect ratio is bugged , i got fullscreen when i need aspect ratio.. what i need to do?" |
07-31-2013, 07:03 AM
I THINK 78HZ IS YOUR MAX!
07-31-2013, 10:34 AM
OK , I KNOW IT NOW. BUT I HAVE OTHER QUESTION , YOU DONT SEE ?
"And when i put 78hz aspect ratio is bugged , i got fullscreen with bugs when i need aspect ratio.. what i need to do?" |
07-31-2013, 04:03 PM
RE: vga monitor refresh rate overclock | |||
07-31-2013, 08:14 PM
Yes , i set in scaling options on nvidia cp Aspect Ratio , and i got fullscreen with bugs (the image is extending beyond the monitor)
08-01-2013, 05:39 PM
That's the monitor then. Since you're using VGA, try auto adjust on the monitor. If "CVT reduced blank" isn't working properly, then just use regular CVT. If that still doesn't work, then the monitor can't handle 78 Hz either. Did it work originally?
